Bentley F133 Revisited.
Hi,
The management want me to start a new thread on this old system, but no help as to where to start it, so If in wrong place stick it where it should be.
Question.
System works as it did when I installed it around 1990 but the outside bell don't ring anymore.  I could replace the whole lot but why?
Before I have a look inside the bell box can anybody remember what was inside?
I'll leave it there at the moment and see what developes.
Cheers
  • Replies 37
  • Views 6.9k
  • probably only me thinking of Hale & Pace?     The OP is probably the only poster ever to put his postcode in "location",  I think I speak for every one on TSI when I express my
  • datadiffusion
    datadiffusion
    Well it certainly won't be any TV commissioner any time soon
  • PeterJames
    PeterJames
    They stopped making 2.6 ah in 1998 the battery should be changed evey 4 years so at the very least the battery has been pulling the charging circuit down for the last 18 years I bet the transformer hu
Any external sounder will do, the Bentley is quite old so before replacing the external sounder I would check that its not a fault with the panel bell output
as above it could be externl sounder. That age it probably isnt an SAB so could be sounder failure, cable failure, panel failure etc etc
Pretty sure they are SCB's on that age Bentley. Maybe even positive trigger?
I would be checking the panel and it's outputs respond correctly to an alarm activation with a meter before even considering the ladders.
possibly pos tamper return too i cant remeber
13 minutes ago, james.wilson said:
possibly pos tamper return too i cant remember
Agreed it was pos return, and pos trigger iirc
I found the instructions, that will help.
(Unusable image removed to save server space)
Edited by datadiffusion
Remove image
i cant make out the connections on that im afraid
Is this any better?1455004544_panelwiring.thumb.jpg.a6d2b2f917bafa7d412fb8a5261279c1.jpg
