Texecom Premier Elite - Door as Entry/Exit by day but guard by night?
4 minutes ago, al-yeti said:
Veritas electrician panel
Premier put in by electrician mostly not set up right
id say thats a lot
  • Replies 22
  • Views 7k
Any panel can be put in wrong, different areas seem to have there own sparky panel of choice.
Kit options as in the panel is modular by design with an array of module options for every problem. The aesthetics of all the kit is far superior too.
Some of the things I remember are lack of:- wiring types, custom outputs, output types, users, log events and on the bigger panels Areas and Zones which is a niche use case but I have fitted 640's in the past.
Yes agreed premier is closer to the dimension etc
For domestic they are getting better , with newer keypads and contacts things will improve
Hkc slow to introduce things but it's not a bad thing as it's not just thrown in desperation like orisec
I like the flush mounts on the texe tho
