Texecom Premier Elite - Door as Entry/Exit by day but guard by night?
Hi people, The title probably says it all. I have a Premier Elite which was set up a year ago, but I didn't quite get around to the final touch. On full arm I have all the zones on guard aside from the front door which is an entry/exit. On part arm, I have all zones on, but the landing sensor off (Part 1 omit) i.e. everything else left as is. In part arm, the front door still acts as an entry/exit meaning that if some miscreants broke the front door down, they'd have 15 seconds to find the keys and key fobs and theoretically disarm the system. Can I tell the front door switch to be entry/exit in the full arm, but guard in the part arm? Currently, every zone is on Area A, but I have a feeling I'm going to be told that I need to start chopping things about... Any assistance gratefully received (I use wintex via the smartcom for programming). Apologies if this has been covered elsewhere on the boards, I have had a look but couldn't find it. Thank you.
Jon
  • Replies 22
  • Views 6.7k
Oh wait a minute I misread your post, sorry
Front Door needs the last attribute called "Guard" enabled.
Edited by sixwheeledbeast
typo
Ugh, it works perfectly. I was sure that I tried that before. Clearly not. Thanks very much for the help 6WB, I'll never darken the doors of this site again with questions so stupid...
1 hour ago, sixwheeledbeast said:
Most things are simple if you know it.
Be serious man , texe is hard than most or maybe still easier than the dimension
6 hours ago, sixwheeledbeast said:
If Texe so hard I have no idea why it's popular with the DIYers but whatever.
Cos you help them proper , good man
I don't know why but all this guard stuff and areas and way it's default setup is quite different from most panels , the odd few I looked at were mostly setup so only had a few issues to deal with
Like any panel have to learn it , but I don't like it's menu structure , but then I don't like hkc structure with numbers lol, I am used to galaxy menu selection by number where hkc and texe both more hassle to remember hence using software quicker
