13 hours ago, datadiffusion said:
If you are struggling now with the water around your ankles, you'll be drowning if you take the lid off and start poking around.
Time to admit defeat and pass this job on to a professional, I'd say.
The jobs All yours with pleasure
12 hours ago, MrHappy said:
 Menvier Security Ltd who where dissolved in 2015
They were as good as dormant for many years anyway, 2015 was just the Eaton takeover, when all the remaining names and subsiduarys were oficially wound up.
Thanks but no thanks.
Edited by datadiffusion
9 hours ago, EECARE said:
The keypad does not operate the numbering when entered
because their worn out,
you need either new old stock or a remote control button repair doodar....
  • 1 month later...
Daft as it is this showed up in another search.
Must will  be loads of keypads not operating correctly, who would of thought a non serviced bit of kit would not work perfectly after 20 or so years.
Hi everyone one, and thank you for all you help.
to update you all I bought a keypad from eBay and turned up at the customers place with the keypad. I opened the existing keypad and noticed that the keypad I had was not the same one. Also the alarm went off.
so needed to think quick, I asked the client if he had son alcohol/spirits and he was helpful to give me a glass.
so with a clean cloth I used the alcohol to clean the existing keypad, this was all going on with the alarm sounding. Have it a good wet clean with the Alcohol. After I put the face plate back on and tried the keypad, it seemed ok to me, so called the client to enter the passcode in and horay it worked.
no question asked none answered.
customer was happy.
what a result.
Easy Electrical
Until the sugar in most alcoholic drinks as opposed to IPA fecks it up worse then the first time round anyway
Register a new account
Sign in
