SW-1070 External Bell Not Sounding
13 minutes ago, Eugene's DIY Den said:
The panel I used is a pro version, I was lucky enough to get it from my electrical suppler. Apparently it's only supposed to be supplied to professional , not sure of the logic of this? Maybe they're afraid of reverse engineering?
Maybe , you got details of who supplied to you?
  • Replies 61
  • Views 13.9k
  • buy a dog...
  • Did you set a bell delay?
  • What happens when you remove the hold off? If the bell doesnt sound then its a faulty bell, if it does, then the next thing to try is put the trigger wire to 0v if it rings then its not the cable.
3 minutes ago, Logan said:
I use orisec and you must be a registered installer to purchase thier equipment
In case you're a  burglar and hack in and remotely control the panel in the future? I presume that's what they're worried about.
Edited by Eugene's DIY Den
That should be easy then....
Thought used enforcer , mini and all that?
did you get an adult to fill out the form ?
I  notice I get an error fault sometimes when I open my front door and the alarm goes off. The frame is swollen with all the rain so the door takes a lot of tugging and pushing to pull it open. Could this be due to the contacts being repeatedly opened and closed, sending multiple pulses to the panel instead of a single open signal?
tamper due to poor connections...
Put a surface mount on , not ideal may work better for you , if difficult to keep connection in frame
Connections are perfect, I always spend ages making them. No corrosion. Fault wasn't a tamper fault.
There's no movement of the sensors though, they're well fixed. What I'm wondering is what exactly "entry fault" means.
