Racal Guardall RLC1 problem
I have a customer with an old Racal Guardall RLC1 Light Control Unit. The external PIR has been damaged and was wondering if someone knew of a direct replacement for thePIR.
Hi and welcome
Racal Guardall stuff is all obsolete now its been a long time since I looked at the external stuff but if it is just low voltage with nc/no circuits you could use a GJD detector or a watchout
  • datadiffusion changed the title to Racal Guardall RLC1 problem
31 minutes ago, Logan said:
I believe any external pir should work but not 100% sure
Depends on a few things, not all will.
Ok boomer
Nah
20 hours ago, PeterJames said:
Map6 was around before the internet So apparently Im a baby boomer
For sure
