GX Remote
3 hours ago, SecureAlarms said:
Ah ok thanks. Not had anything emailed. I will try this again with another email account maybe.
Sorry, it's actually given as part of the registration part.
  • Replies 44
  • Views 11.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • No worries. I can take a look at the server side to determine the issue for you if you need help.   Although SelfMon costs £1 a month, it gives many options for filtering events and directing to diffe
  • Logan is 13 or something dude , just for clarity (no offence Logan of course )
  • They should be emailed to the email address you set up via the app. Just a server address, port number and account number.
Posted Images
That has already been done. Im just not sure where i need to apply the information.
Menu 56, ethernet settings
www.nova-security.co.uk
www.nsiapproved.co.uk
The destination IP, port and account number can be applied to the Alarm Monitor or ARC sections.  You must also be transmitting in SIA format.
21 minutes ago, Logan said:
Seems that @al-yetiand me found a panel we both like
I might have gone Eaton scantronic if all devices were two way , to late tough
It's interesting that Eaton don't seem to state what their app encryption actually is.  "Market Leading" and "Internally tested by their own experts" means nothing.   At least Honeywell's app states that it uses AES. It does also perform per session RSA key exchange too, but for some reason they don't mention that. The only thing that lets it down security wise is that there's no certificate, so the connection is susceptible to a man in the middle attack.
I know that Texecom hastily added AES, but they generate a fixed key and that's not good either.
Yeti, do you have more info as to the actual encryption used by Eaton ?
Data fusion has that info
And I am 100% the Eaton man scantronic is reading this
What have you done!
Latest V6 Eaton firmware is all about security, security, security, there must have been a major encryption change of some kind as all app users have to reregister, this has not happened with previous incremental updates.
