Galaxy group setup
yes the max settings arnt in the keypad menu
  • Replies 20
  • Views 3.9k
  • That was hard work! Setting up the fobs to work the same way was in a completely different menu. It all worked in the end.  thanks for the help guys, really appreciate it.
  • Useful if you want to arm an annexe or only door etc stuff like that
  • So we had to use areas because the client had an office space split over 2 floors and wanted more flexibility.  I can’t see a good reason to use it at home unless you had a completely separate area.
3 minutes ago, Logan said:
I can't figure out how to do this on my galaxy
Cos you got an old junk version
Start a new topic logan and lets see what it is
56 minutes ago, Logan said:
Pessimist
Seriously though, yours won't do what the dimension can do
  • 2 weeks later...
Hi @tinnitus
I was thinking of setting groups up on mine but couldn't see what benefit I would get.
It's it only really helpful if you have a keypad upstairs,
I'm only having them downstairs at each door.
I'd start a new topic based on your requirements
I didn't want to spam the forum with new posts.
I don't really have any requirements just saw him talking about it so thought I'd ask.
In your scenario as you say no real benefit.
4 hours ago, Steve23 said:
Hi @tinnitus
10 hours ago, Steve23 said:
Hi @tinnitus
I can’t see a good reason to use it at home unless you had a completely separate area. I’d say part set and full set are all you need.
what did you need to do?
