Galaxy group setup
Hi guys,
I have a galaxy system split over two floors, keypad on each floor. Both floors have been split into groups, 1 and 2. Is it possible to designate floor 1 keypad to group 1 (floor 1) and that is the only set point for that floor and the other  keypad to the other group and that will only set that group (2nd floor) effectively 2 separate systems. It would be great if we could use the same fob or code on both floors without selecting the group. Also, I’m assuming the exit tone will still be heard on both floors at the same time? They are wired into separate outputs.
thanks in advance guys, sorry for the long drawn out post.
  • Replies 20
  • Views 4.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • That was hard work! Setting up the fobs to work the same way was in a completely different menu. It all worked in the end.  thanks for the help guys, really appreciate it.
  • Useful if you want to arm an annexe or only door etc stuff like that
  • So we had to use areas because the client had an office space split over 2 floors and wanted more flexibility.  I can’t see a good reason to use it at home unless you had a completely separate area.
use group restrict on the max, keypad and user. Program the user to both groups. re the sounder just program as e/e horn for each group
it is. But you need to add group restrict to the users too
Sorry James I didn’t see your reply. Thanks for that. Do I not need to assign each keypad to the group in menu 58?
So when I’m in user codes, I go to the user, modify group, then what? I’m assuming the user should have both groups but no “*”, that way they can set both groups without a choice but the keypad is what decides the group?
Also, do I now need to disable groups again in menu 62?
That's it but no don't disable groups you need them
Can I restrict the keypad E/E tone to each group?
Edited by tinnitus
yes just set the groups in the keypad output
