Galaxy group setup
15 hours ago, tinnitus said:
So we had to use areas because the client had an office space split over 2 floors and wanted more flexibility.
I can’t see a good reason to use it at home unless you had a completely separate area. I’d say part set and full set are all you need.
what did you need to do?
Thanks,
No there's no specific area I need separate.
I'll leave that alone then :lol:
  • Replies 20
  • Views 4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • That was hard work! Setting up the fobs to work the same way was in a completely different menu. It all worked in the end.  thanks for the help guys, really appreciate it.
  • Useful if you want to arm an annexe or only door etc stuff like that
  • So we had to use areas because the client had an office space split over 2 floors and wanted more flexibility.  I can’t see a good reason to use it at home unless you had a completely separate area.
