Alarm design advice for 3 bedroom house
4 minutes ago, EDinMK said:
But anyway I have decided to PIR that room as its locked when they go out anyway
Just put a PIR on the landing like most would - unless there is a flat roof entry to one room only is rare (and even with the flat roof it is rare to go in and out to one room)
A PIR on the landing catches people coming out from 1st floor entry, or those boshing the front (or back) door and running straight up the stairs for the bedroom jewelrly.
A dialler unit to call relatives
No no no - forget this neolitic technology. This is why we've steered you towards the likes of Texecom.
Do they have t'interwebs at their house?
It's rare a kit will have everything you need - its usual to buy a kit and then add what you need.
Edited by datadiffusion
  • Replies 49
  • Views 7.8k
  • For less than the cost of a mobile phone you are protecting your most valuable asset!
  • thats what i did Al,   but the Yale is a Shiece of Pit! it doesnt have a wired sounder and it doesnt have the range of accessories  and its not for me      I gu
  • james.wilson
    james.wilson
    A bit of cable here and there
kits are generic and usually put together. Few pro installers would use a kit they should pick the right detectors etc for the application. Now your seeing why kits are far from ideal as there has to be a compromise somewhere
also pstn is being switched off by 2025 so best not install something that can only use it
If not vote Jez ;)
LOL someone registered 'britishbroadband.net' this morning, though the .com has been biding it's time since 2002 :)
Well they do have internet for sure.
Cant have anything on stairs as dogs run up there too.
So with Texecom I can get a dialler unit ?
I just though a nice bundle would reduce the cost ...
Is there only really TWO affordable/quality self fit alarm alternatives ..Tex or Pyr
seems a narrow market to me
no there is Honeywell, Visonic, Scantronic, EL, Vanderbilt, UTC to name a few. there is also the restricted stuff like hkc
Yes free broadband aswell
yes im getting ready for the  redundancy, we do loss covering when its likely to come back, going into December im gonna have convert my garden and brick a few windows up, this is an old policy right...
omg ..i found this site that seems to do all the names above
but by god is it confusing
https://www.securitywarehouse.co.uk/
how d i KNOW if the control unit supports a wired bell?
and whats the deal with no backplate and cover...er ...isn't that all there is !
Looks Good!
But I have ANOTHER enigma, and i have watched videos on youtube etc ..but none seem to show this.
Basically if you look at their windows (below)
you can see the window is a GOOD 3/4 inch deeper than the actual frame.
I mean i know the magnetic contact always goes window/door side. but even when closed it will be still a good 5mm away from even lining up opposing edges
never mind facing !
and i am presuming it needs to be facing each other ....so would this be a "packer" job ? I mean I dont recall ever seeing a magnetic contact
sitting or jutting out on what would be a lego brick block before
or am i not looking LOL
Yes or use a flush cabled one and wire it into the shock etc
