Andy cb Posted October 25, 2019 Author Share Posted October 25, 2019 19 minutes ago, Andy cb said: But how do I stop the case all the tamper switch is fitted to the circuit boar and in to the case don’t think I can get the tamper switch out without damage Swap the case Quote Link to comment Share on other sites More sharing options...
al-yeti Posted October 25, 2019 Share Posted October 25, 2019 1 minute ago, Andy cb said: Swap the case In new one disconnect the speaker from the circuit board and use it as you did your old Or swap the case damaging the tamper switch won't matter Or use this new one as an internal bell and use it on outputs and keep broken one connected as is Just swap the case as said above Quote Link to comment Share on other sites More sharing options...
Andy cb Posted October 25, 2019 Author Share Posted October 25, 2019 (edited) I want to keep and use tamper speaker is soldered into circuit board so would need to cut it out to swap case over I think I would run risk of braking new case as I try to take out speaker, circuit board and LED Edited October 25, 2019 by Andy cb Quote Link to comment Share on other sites More sharing options...
al-yeti Posted October 25, 2019 Share Posted October 25, 2019 3 minutes ago, Andy cb said: I want to keep and use tamper speaker is soldered into circuit board so would need to cut it out to swap case over I think I would run risk of braking new case as I try to take out speaker, circuit board and LED You can disconnect the tamper aswell and use that on a tamper circuit Either way you can't use that circuit board on the speaker output simple Quote Link to comment Share on other sites More sharing options...
Andy cb Posted October 25, 2019 Author Share Posted October 25, 2019 1 hour ago, Andy cb said: But how do I stop the case all the tamper switch is fitted to the circuit boar and in to the case don’t think I can get the tamper switch out without damage Swap the case 11 minutes ago, al-yeti said: You can disconnect the tamper aswell and use that on a tamper circuit Either way you can't use that circuit board on the speaker output simple Ok I think I need to return it am I right I’m needing to CQR soint1 I posted about earlier Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted October 25, 2019 Share Posted October 25, 2019 There's not much to it, you either send it back and have to wait and pay again or... a) remove all the electronics from both cases and swap them over b) snip all the black wires on the new unit close to the PCB, remove PCB fit and wire the terminal blocks like in the original. 1 Quote Link to comment Share on other sites More sharing options...
MrHappy Posted October 25, 2019 Share Posted October 25, 2019 6 minutes ago, sixwheeledbeast said: There's not much to it, you either send it back and have to wait and pay again or... a) remove all the electronics from both cases and swap them over b) snip all the black wires on the new unit close to the PCB, remove PCB fit and wire the terminal blocks like in the original. choc block onto speaker, retain driver board for tamper, easy ? 1 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted October 25, 2019 Share Posted October 25, 2019 If you don't mind the terminal strip floating around yer. Quote Link to comment Share on other sites More sharing options...
Andy cb Posted October 25, 2019 Author Share Posted October 25, 2019 (edited) 5 minutes ago, sixwheeledbeast said: If you don't mind the terminal strip floating around yer. So what your saying is snip all the black wires from the new speaker and the new tamper switch take out the circuit board and led and just use the connector bloc from old sounder Edited October 25, 2019 by Andy cb Quote Link to comment Share on other sites More sharing options...
al-yeti Posted October 26, 2019 Share Posted October 26, 2019 14 hours ago, Andy cb said: So what your saying is snip all the black wires from the new speaker and the new tamper switch take out the circuit board and led and just use the connector bloc from old sounder Yes but your going in circles now read all answers more or less what they been saying all along Quote Link to comment Share on other sites More sharing options...
