Am89 Posted August 29, 2019 Share Posted August 29, 2019 Hi hoping someone can help. My home alarm is beeping / showing low batt in hall way - seems to be a low batt inside the panel. Can anyone advice what batt I need and how to replace myself.  Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/ Share on other sites More sharing options...
MrHappy Posted August 29, 2019 Share Posted August 29, 2019 if you want a panel battery-  https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/intruder-alarm-ancillaries-c-36_46/pyronix-battenf8xaa-battery-for-enforcer-32we-homecontrol-p-5345.html Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488179 Share on other sites More sharing options...
Am89 Posted August 29, 2019 Author Share Posted August 29, 2019 12 minutes ago, MrHappy said: if you want a panel battery-  https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/intruder-alarm-ancillaries-c-36_46/pyronix-battenf8xaa-battery-for-enforcer-32we-homecontrol-p-5345.html Cheers - is the Pyronix, BATT-ENF8XAA the batt I need and will it be located inside the panel? Think I just need to remove 2 screws, remove old batt and Insert new one? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488180 Share on other sites More sharing options...
PeterJames Posted August 29, 2019 Share Posted August 29, 2019 Call me old fashioned, but if it says low battery in the hallway then surely its the battery in the detector in the hallway Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488183 Share on other sites More sharing options...
Am89 Posted August 29, 2019 Author Share Posted August 29, 2019 Could be ^^^. Try that first then - rather than panel? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488184 Share on other sites More sharing options...
al-yeti Posted August 29, 2019 Share Posted August 29, 2019 56 minutes ago, Am89 said: Could be ^^^. Try that first then - rather than panel? Yep says wireless  Might throw an engineer tamper , you got the engineer code ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488189 Share on other sites More sharing options...
Am89 Posted August 29, 2019 Author Share Posted August 29, 2019 Last time I took off sensor it didn’t ask for an engineer code so hopefully won’t ask this time. Any idea the name of the battery I need to the sensor - think it’s a small round one usually? Thanks for the info Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488190 Share on other sites More sharing options...
sixwheeledbeast Posted August 29, 2019 Share Posted August 29, 2019 CR123 is pretty standard for most wireless sensors now. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488194 Share on other sites More sharing options...
al-yeti Posted August 30, 2019 Share Posted August 30, 2019 2 hours ago, sixwheeledbeast said: CR123 is pretty standard for most wireless sensors now. No I think the enforcer old contacts are stupid like the visonic ,  Most take cr123 but some contacts take the smaller cr2 or something like that on visonic shock ,  I think one type of contact is different on these aswell  But open the thing man and look wasting time typing here lol Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488199 Share on other sites More sharing options...
sixwheeledbeast Posted August 30, 2019 Share Posted August 30, 2019 Who said it was a door contact? Opening the device is the obvious solution. I did say most, that said you still have to carry a stupid array of batteries as an engineer, I am not going to list them all. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488201 Share on other sites More sharing options...
