August 29, 20197 yr comment_488177 Hi hoping someone can help. My home alarm is beeping / showing low batt in hall way - seems to be a low batt inside the panel. Can anyone advice what batt I need and how to replace myself. Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 29, 20197 yr comment_488179 if you want a panel battery- https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/intruder-alarm-ancillaries-c-36_46/pyronix-battenf8xaa-battery-for-enforcer-32we-homecontrol-p-5345.html Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488179 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 29, 20197 yr Author comment_488180 12 minutes ago, MrHappy said: if you want a panel battery- https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/intruder-alarm-ancillaries-c-36_46/pyronix-battenf8xaa-battery-for-enforcer-32we-homecontrol-p-5345.html Cheers - is the Pyronix, BATT-ENF8XAA the batt I need and will it be located inside the panel? Think I just need to remove 2 screws, remove old batt and Insert new one? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488180 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 29, 20197 yr comment_488183 Call me old fashioned, but if it says low battery in the hallway then surely its the battery in the detector in the hallway Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488183 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 29, 20197 yr Author comment_488184 Could be ^^^. Try that first then - rather than panel? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488184 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 29, 20197 yr comment_488189 56 minutes ago, Am89 said: Could be ^^^. Try that first then - rather than panel? Yep says wireless Might throw an engineer tamper , you got the engineer code ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488189 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 29, 20197 yr Author comment_488190 Last time I took off sensor it didn’t ask for an engineer code so hopefully won’t ask this time. Any idea the name of the battery I need to the sensor - think it’s a small round one usually? Thanks for the info Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488190 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 29, 20197 yr comment_488194 CR123 is pretty standard for most wireless sensors now. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488194 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 30, 20197 yr comment_488199 2 hours ago, sixwheeledbeast said: CR123 is pretty standard for most wireless sensors now. No I think the enforcer old contacts are stupid like the visonic , Most take cr123 but some contacts take the smaller cr2 or something like that on visonic shock , I think one type of contact is different on these aswell But open the thing man and look wasting time typing here lol Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488199 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 30, 20197 yr comment_488201 Who said it was a door contact? Opening the device is the obvious solution. I did say most, that said you still have to carry a stupid array of batteries as an engineer, I am not going to list them all. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43084-battery-replacement/#findComment-488201 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
