ScanTronic 9651 keypad replacement
I would charge the RKP out at £75 plus 2 hours labour (but I would include 4 fobs); more if I need to crash the system (although if you're lucky you can default only the codes).
I expected approved to be much more TBH.
You £99 brigade lot
£59.99 for defaulting
£cost of keypad
£79.99 for keypad changeover including fobs
No just greener, its only a flap broken so why change the whole keypad?
You've got a supply of spare flaps?
No he means charge them full price regardless , but only for flap and keep new keypad part in a box somewhere
Nice one Rodders
Thanks everyone. Turns out that the code on the paperwork is the ‘job number’ and not the installer code.
As everything works perfectly, and it’s just the plastic flap that’s come off, it’s going to be hard to justify £150 so I guess it’s going to have to be something I live with for now. I still have the flap, may see if I can fix the hinge somehow when I get some time.
