New keypad
37 minutes ago, james.wilson said:
Don't see any issues with the accentas etc. Sia have loads of optimas still supported
That one was the first I've used & it was a quick and easy install for the panel, it's pre programmed for most small domestic installs so little to change. Programming is easy & as I said it proved reliable, think it was in about 8 years total & all it needed was normal yearly service.
Suppose it's a bit like people's view on the Logic 4, a lot of people hated them. But I never had any problems with them. I've got one still in daily use, again in a small garage & it's worked faultlessly for 20 years.
Edited by Specialist
  • Replies 22
  • Views 6.1k
  • PeterJames
    PeterJames
    If you can get one the same, then you can just replace the rkp
  • sixwheeledbeast
    sixwheeledbeast
    One of those 700L rebrands I believe. If you can find a keypad just swap it over, although you maybe better just upgrading for something that comes as a panel and keypad if you feel competent to
  • Specialist
    Specialist
    I think you'll be lucky to find parts for it now, it wouldn't cost that much to fit a new panel and keypad. Why does the lid keep popping off, is the little securing screw missing ?.
2 hours ago, Specialist said:
Never met this Chlamydia girl, from down your way is she ? ;-)
Posh sort you'd met at the gymkhana...
I gave up on them some yrs ago, its getting pulled for a veritas or euro-m
Aah now I know why I've never met her, She's posh totty for the horsey setB)).
Like your choice of panels, I've used both to good effect.
Agreed the euro mini has positives but few optimas or accentas fail. I'd put an xm6 up against pretty much anything else for longevity
Mr h isn't a panel snob, he made me accept the Premier was a decent panel
You ever used any of the MDT panels James ?.
Grey for away red for bed that's how I sell petes fobs , they were ok ish panels, I still look after errrrr only two now rest upgraded
Firm I worked for many moons ago installed a few of them in corner shops, can't say I liked them. They were just way too cramped inside.
Installed no
Just wondered if you had & what your impressions were. As I say I found them very cramped, especially if you used all zones.
Any idea what happened to MDT ?.
Went bust but of course they cashed in ......
I got a panel somewhere if you want it
