Guardall PX500 Problems
Got problems with a Chubb Guardall system. Need to get a new one of these...but what are they...id biscuits?? Chubbs own? Can’t find anything to help me so any help greatly appreciated.
Looks like it, cut heat shrink off should have a number on it maybe?
They are the special parallel Guardall EOL's, highly doubt it would be faulty and could be tested with a meter.
Thanks everyone for your help I’ll give it a try.
Got to get Chubb in to default the engineer code/pin of the day rubbish as well.
Hopefully the customer will just go for the Texecom system we recommend.
I wouldn't recommend taking over a PX if you have never used them before.
Also you will need to replace all the EOL modules and possibly some devices if you swap the controls.
Its as above EOL resistors in heat shrink made by elemdene 8K2 / 8K2
www.nova-security.co.uk
www.nsiapproved.co.uk
Thanks I’ll get in contact with them.
