Good morning everyone. First post and I’m hoping someone can recommend the best way to deal with my problem.
Our house was prewired in preparation for an alarm installation. All the cables are in place around the house and just need the key pads, sounder, pirs wiring in. However the problem is that the cables terminating back to the control box site have been cut way too short. The cables will not put through any further and the flooring above is not accessible in any shape or form (wet room). I don’t want a wireless system.
I’m planning on fitting a Texecom Premier Elite 24 (either Polycarbonate or metal).
Any suggestions on the best, neatest way to extend the cables? The control panel will be fitted immediately to the left of the cables at the same height. See image.
THANK YOU
THANK YOU
Just join crimp , solder and extend cables etc
You could bury them in wall and put a face plate on top after
I would open the plaster up more towards ceiling and fit panel higher up if possible then joins can be inside panel
Do you have a better picture?
11 minutes ago, Al H said:
Thanks to you both. Really appreciate your support. Ill go ahead and order the Polycarbonate version unless you think different.
Thanks again both
Thought steel version has more space
Swb?
22 minutes ago, MrHappy said:
Bad design, row or 20mm holes in the middle of the enclosure.
I'd put a plastic expander on the short wires
Yes cable.management is more on hkc stuff aswell in my opinion
Galaxy range and texecom have better space to lash it in
Register a new account
Sign in
