Scantronic kp01 keypad help!!
Hello. I hope someone can me on the issues that I am encountering. I have a Scantronic ion 30ex, which was installed by a professional. Whilst decorating, I disconnected the second KP01 Keypad (in engineer mode), reconnected it once finish decorating and now the navigation button is flashing red. I have tried re scanning for bus addr  , but when pressing A + tick on the second keypad , it shows up further details but its not assigning.  If someone can advise on how to resolve this it would be much appreciated.
Thank you
Does it come out of engineer mode?
It should tell you the issue if it doesn't.
Keypad will have went red as you created a keypad tamper.
Won't go green again till it's out of engineer mode/keypad tamper resolved.
You definetly connected it correctly?
Thank you all for coming back to me. I have checked the wires and all are connected correctly. I am following the steps below
1. go into engineer mode via keypad 1
2.go to add bus option
3. go the keypad 2 and press A and tick which displays
 B1 d52 t00, v3.11
4. At this point, from my understanding, this will assign the keypad. But no further progress , and keypad 1 still states, 'Press addr button etc.
5. I exit from engineer mode, key pad 1 is green, but keypad 2 still flashes red.
Any further help would be appreciated.
 B1 d52 t00, v3.11
Check cable then , resistance etc, power etc
I thought displaying those details meant there's no coms coming in correctly
When you say disconnected in engineer mode, do you mean you used the remove keypad option then powered down before removing the keypad ?
If you didn't use the above option, then my best advice would be to contact your original installer and pay them to sort it out for you.
The ion's are excellent but really not a DIY system and it may need to be powered down, defaulted and re-programmed.
Edited by Specialist
 B1 d52 t00, v3.11
Dude
Simple process for you
Swap both keypads round
If keypad one works in position 2 atleast you know for sure to an extent the cable power and coms is good
Then it has to be addressing and programming or the keypad itself
