Galaxy Flex 20 with RF & RIO
1 hour ago, Nova-Security said:
Not sure on the flex but 12 zones on the panel ? add an RF module doesn't that take 8 up making 20 and your panel is a flex 20
I thought you could do RF on all the zones like the g2 , your thinking dimension?
  • Replies 25
  • Views 9.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Okay, checked this out on the Flex with a RIO.  So what you need to do is configure the virtual RIO in the RF portal so that it doesn't take any addresses up.  Ie. No virtual RIO enabled. Then you can
Posted Images
so what are you RF zones numbers 1021 to 1028 ?
I can see these zones in the display zones menu (Menu 21):
1001 > 1004
1011 > 1018
1021 > 1028
I know 1001 through 1018 are the Main board, can't see if the 1021> Zones are the RF or the RIO, I expected the address of the RIO & RF to dictate the zones like this:
RF Module (Address 5) : 105x
RIO Unit (Address 3) : 103x
But its more likely I have misunderstood the manual.
Edited by RevolvingSteve
OK, so further info:
If I use menu 52.1 (Program Zones > Zones) I see:
1001 > 1004
1011 > 1018
1021 > 1028
If I go into 52.2 (Program Zones > RF Zones)  I see:
1021 > 1028
Not sure if there is a better menu to view this.
Only installed one flex, use G3 all the time
www.nova-security.co.uk
www.nsiapproved.co.uk
The RF portal can have up to three virtual Rio addresses. They are not the same as the physical bus address of the portal.  The virtual Rio addresses are in menu 56.60.1
The last time I looked at this, the Flex would not allow the portal to coexist with the Rio on an fx20 in the way that was allowed on the older g2-20 panels. The panel responded differently depending on which module was added first (Rio or portal).
IfI get a minute, I will test that this is still the case at the latest Flex version 3.50.
Wonder why they called it flex , not very flexible then
No surprise I have managed to end up with the complicated version LOL
OK, very grateful if you do get time. I don't actually need the RF portal yet (although I will) so is there a way to remove the RF Portal to allow the RIO to be picked up whilst sorting out if there is a solution?
Agreed!
Just remove the portal and scan devices in menu 72 - * to delete. Then scan again to find the RIO.
I think the intent is to stop zone expansion beyond the 20 zone limit of the panel, but you should be able to expand to 20 zones max and have any of the 20 hardwired or wireless. It seems that this may not be an option with the FX20 and you can only have 12 hardwired and a possible 20 wireless. If you upgrade to an FX50 or FX100, you can have a number of RIO's fitted.
As I said, I thought that this was a bug in the early Flex and I never went back to see if it was fixed in the newer models, as I only use the FX100+ now anyway.
Is then, 72, then *? doesn't seem to do anything.
Does the FX50 fit in the same housing?
Is it just the zone qty that's different between the models?
The process is:
  1. Start the Auto-learn mode in menu 72.
  2. Remove the device from the data bus (for example disconnect the module).
  3. Exit from the Auto-learn mode and confirm the address of the device removed (using *).
  4. Enter Auto-learn mode once more.
Yes, the boards across the range are the same form. Only different between the metal case and plastic case boards.
The Flex+ supports grade 3.  The 50 and 100 series panels support more users, zones, outputs, bigger event and access logs, schedules, keypads and links.
