Galaxy Flex 20 with RF & RIO
Some free time again so back onto the Alarm.
I seem to have everything working on the main panel now and have been setting the alarm for a week or so, no issue!
Now I want to add the RIO expander to put the extra door contacts in. I have fitted it and wired the RIO back to the Lfex on the same terminals as the KeyPad, I have a flashing green light on the RIO now, but cannot see anything that it has recognised the RIO or any extra zones in the zones menu?
Any ideas?
  • Replies 25
  • Views 10k
  • Okay, checked this out on the Flex with a RIO.  So what you need to do is configure the virtual RIO in the RF portal so that it doesn't take any addresses up.  Ie. No virtual RIO enabled. Then you can
List zones showing in menu
When you added the Rio did you address it enter engineer mode then exit , I assume adding a Rio hasn't changed on the flex then when exiting it says new mod added
Which firmware version flex? I seem to remember some issues trying to mix fx20 with portal and RIO. Never had the problem on fx50 or fx100.
Yep, I didn't the enter/exit Eng mode, didn't show anything new (was 12, now 12.. I think from memory)
On 20/02/2019 at 13:08, al-yeti said:
Did you address correctly
I have the addresses set as follows:
KeyProx 1 : 0
KeyProx 2 : 1
RF Module : 5 (no idea why I set it to 5?)
RIO Unit : 3
As always, thanks for the time and help.
Not sure on the flex but 12 zones on the panel ? add an RF module doesn't that take 8 up making 20 and your panel is a flex 20
www.nova-security.co.uk
www.nsiapproved.co.uk
I thought the RF Zones were not included in the '20'? But I'm not 100%
so what are you RF zones numbers 1021 to 1028 ?
