2 minutes ago, sixwheeledbeast said:
Whats on Zone 8? It's likely unrelated to the bellbox being a Zone
It says "technical" on instruction manual. only 1-4 zones are used.
Technical (TC) (Key in 08). Use this zone type when you want to monitor equipment, for example a freezer, without raising a full alarm. If a technical alarm zone is activated while the system is set, the system makes no audible alarm. However, when a user unsets the system the keypad indicates a fault.If a technical alarm zone is activated while the system is unset then the system starts a pulsed tone from the keypad. If programmed, the control unit also starts communication. When a user enters a valid code the keypad stops the tone and displays the zone.
Edited by Carlos12
Link it or make it used or spare
  • Upvote 1
Just now, Carlos12 said:
1301167384_WhatsAppImage2019-01-19at13_56_27.thumb.jpeg.7b2d1b3ce753f850030ccd272ea7c7bc.jpeg
Now the alarm has frozen? It doesn't seem to be responsive, I've taken all my links out, and placed existing back in, battery off, kick started and same issue?
I really appreciate your help.
Coms to keypad might be missing check connections to keypad.both ways
You have only one keypad yes?
  • Upvote 1
PERFECT!! We're sorted.
Just a few more issues:
Smoke Alarm,Fault?! Zone 10
Door chime not working?
And how to do I change user codes?
I've checked instructions but unable to find any information, thanks.
Edited by Carlos12
Everything is functional apart from the door chime.
I've changed the settings on the keypad, to OFF and back ON, it makes the sound - but when the sensors move theres no sound?!
What could be the explanation for this?
I really appreciate your help, every days a school day! Thanks so much, my neighbour will be so chuffed it's fixed
Register a new account
Sign in
