Honeywell Galaxy Flex 20 > PIR Wiring
1 hour ago, RevolvingSteve said:
Im going to run out of PIR zones as there are only 12 on the board.  'Garage' for example I am happy to have both PIR on 1 zone.  Thought that was OK, but please advise if Im being dumb!
So you need to buy a Rio to expand the wired zones
Galaxyguy if your reading?
Is flex20 same as g series you can use any zone as wired and wireless
If that's correct buy a Rio , expand fully and then do what you have to do
  • Replies 26
  • Views 16k
  • 1 month later...
Right, after 3 weeks of Xmas madness I got back onto this today.
Fired the alarm up and I have one fault which is 'Tamper O/C' on zone 12 (1018 from memory), which is the door contact for the back door.  The issue I have is that the door contacts only have 2 wires (Black/Red) so they don't seem to have a tamper circuit or anywhere to fit a resistor?
I presume this is done at the board, but should the resistor just be inline on the '12' terminal?
I'd assume your mickey mouse contacts could be made usable with a jb or soldiering iron ?
Yep, maybe I just bought the wrong ones!
Ive just checked and here:
https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/door-contacts-switches-c-36_44/cqr-grade-3-white-surface-door-contact-with-magnetic-detection-p-4714.html
It seems to imply they do have resistors? Am I just being thick?
Edited by RevolvingSteve
Looking at this page:
https://www.cqr.co.uk/images/stories/cqr_pdf/Magnetic Contacts/Surface Contacts.pdf
Looks like I've ordered the wrong one! They are pre-wired but Ive got type B:
Type B Resistor (For Scantronic, Cooper, Pyronix PCX, Texecom, Castle-Care Tec G3+) [SC513/WH/G3/B] - 4k7 Ohm Switch, 2k2 Ohm Tamper
I need Type A:
Type A Resistor (For Honeywell, Microtech (Galaxy) - 1k Ohm Switch, 1k Ohm Tamper
Rookie error I think!
I need Type A:
Your panel came with resistors somuse them dude if that makes sense
Someone's already done a drawing somewhere here
31 minutes ago, MrHappy said:
program the values to suit the contact ?
If that's possible? I'll have to consult the manual....
The drawing is mine, but that's fine for the PIR's, this is for door contacts with resistors moulded into the unit so I cant get to them.
