andiesstuck Posted November 10, 2018 Share Posted November 10, 2018 I changed a battery in the dining room PIR and the alarm now won’t set.Displays says:!!Enter Code!!!!!Check!!!I enter code and hit reset and the internal alarm starts sounding and display again says!!Enter Code!!!!!Check!!!I enter code again and it saysDining Rm RPI T!I’ve searched online (I know nothing about alarms) and I’ve tried stretching the spring slightly but still the same. I’ve tried attempting to set whilst holding spring down and get the same error.Please does anyone have any other suggestions? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42504-risco-eurosec-tamper-reset/ Share on other sites More sharing options...
al-yeti Posted November 10, 2018 Share Posted November 10, 2018 6 hours ago, andiesstuck said: I changed a battery in the dining room PIR and the alarm now won’t set.Displays says:!!Enter Code!!!!!Check!!!I enter code and hit reset and the internal alarm starts sounding and display again says!!Enter Code!!!!!Check!!!I enter code again and it saysDining Rm RPI T!I’ve searched online (I know nothing about alarms) and I’ve tried stretching the spring slightly but still the same. I’ve tried attempting to set whilst holding spring down and get the same error.Please does anyone have any other suggestions? Do you have any other codes? You probably need an engineer reset , so you need to call someone anyway now Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42504-risco-eurosec-tamper-reset/#findComment-480571 Share on other sites More sharing options...
PeterJames Posted November 11, 2018 Share Posted November 11, 2018 Tamper dining room, either the lid is off the detector or the cable is damaged,it wont clear until you have fixed the fault Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42504-risco-eurosec-tamper-reset/#findComment-480587 Share on other sites More sharing options...
Amps Posted November 12, 2018 Share Posted November 12, 2018 There was a discussion on a Facebook security group about tampers being engineer reset on grade 2 systems. The standards say grade 2 tampers are user rest but some were saying they programme tampers for engineer reset as they do not like the end user to interfere with the control panel. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42504-risco-eurosec-tamper-reset/#findComment-480589 Share on other sites More sharing options...
aissecur Posted November 12, 2018 Share Posted November 12, 2018 I would check that tamper spring clicks when the cover is fitted and that the cover is seated correctly, then wait a couple of minutes then trigger the detector (so it sends a new signal to the panel) then type your code in. Is it possible that the system has been set up for engineer reset on tamper. If the above fails then you will have to make a call to the installing company / current maintainer Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42504-risco-eurosec-tamper-reset/#findComment-480591 Share on other sites More sharing options...
MrHappy Posted November 12, 2018 Share Posted November 12, 2018 You really need to be an alarm engineer to change the batteries in risco radio alarm... Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42504-risco-eurosec-tamper-reset/#findComment-480598 Share on other sites More sharing options...
al-yeti Posted November 12, 2018 Share Posted November 12, 2018 34 minutes ago, MrHappy said: You really need to be an alarm engineer to change the batteries in risco radio alarm... Proper Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42504-risco-eurosec-tamper-reset/#findComment-480599 Share on other sites More sharing options...
MrHappy Posted November 12, 2018 Share Posted November 12, 2018 2 hours ago, al-yeti said: Proper Its quirky, you need product knowledge to clear "faults" Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42504-risco-eurosec-tamper-reset/#findComment-480607 Share on other sites More sharing options...
al-yeti Posted November 13, 2018 Share Posted November 13, 2018 2 hours ago, MrHappy said: Its quirky, you need product knowledge to clear "faults" Yep Hi Honeywell wireless can be buggy to , amount of restarts needed sometimes before something clears , bugged panels hanging around texe maybe Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42504-risco-eurosec-tamper-reset/#findComment-480612 Share on other sites More sharing options...
