GT490X fault - no repair apparently possible
  • Replies 32
  • Views 8.7k
I have never seen a vocomm have a fault on a 490X panel. Has it ever worked since install and did the engineer do checks on the panel and phone socket side?
Some wont work without a BB filter........ thats a point actually IA does the line have broadband?
Yes, the dialler was triggered about 6 months after installation; I left a window open a couple of inches, which was enough to make the curtains sway and the movement was picked up, so I got the call on my mobile.
I was more careful after that, but just assumed the dial function was checked on each annual visit.
Rare though
Ive known companies like Banhams to write off the panel when something doesnt work, where as  a small independent would try and fix it
Not always, the same thing could be said about nationals fixing and indis condemning.
Yes, it does have broadband - I have the normal twisted pair to the house.  The dialler worked while I was out of the house, so no actual BB activity at the time.  But when the engineer tested the dialler I was watching him, so no activity then either.  However, some transient BB activity could have sprung into life at any time, I suppose.  However, I would be surprised if the dialler did not have a BB filter; it must be a no-brainer for installers these days.
I would be very surprised  if an ADSL filter was in place
Even more surprised is the line was in telephone cable
& proper shocked if the eng that came on site had a telephone set to test the line with....
I still got my yellow bt butt phone as they would call it
