May 31, 20188 yr comment_476883 Hi, I have wired in a roller shutter door to one of the relays on the net2 unit and on the programme set it to toggle. It will open the door but wont close it. The roller door unit is set right. Maybe it shouldnt toggle? or i have put the wires from the door in the wrong way. Ideas appreciated Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42129-paxton-door-control-roller-shutter/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 31, 20188 yr comment_476885 is the shutter an auto close one? I would also say it shouldnt be toggle as it will stay active until a valid card is presented or rte is pressed securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42129-paxton-door-control-roller-shutter/#findComment-476885 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 31, 20188 yr comment_476887 I imagine it will require a pulsed input with a timed closure and hopefully trap protection is up to spec... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42129-paxton-door-control-roller-shutter/#findComment-476887 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 31, 20188 yr Author comment_476890 It has a laser break for safety installed. The problem we keep having is that its set on timer down but the moment the time lapses it starts to raise again?? Edited May 31, 20188 yr by forumflyer Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42129-paxton-door-control-roller-shutter/#findComment-476890 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 31, 20188 yr comment_476892 3 hours ago, forumflyer said: It has a laser break for safety installed. The problem we keep having is that its set on timer down but the moment the time lapses it starts to raise again?? id assume then it wants a pulse to open? then time out and reclose? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42129-paxton-door-control-roller-shutter/#findComment-476892 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 1, 20188 yr comment_476895 On 31/05/2018 at 18:27, forumflyer said: It has a laser break for safety installed. The problem we keep having is that its set on timer down but the moment the time lapses it starts to raise again?? How have you interfaced the two , diagram? I just interested on the roller control side , meaning how did you wire it? Onto the shutter switch? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42129-paxton-door-control-roller-shutter/#findComment-476895 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
