Pyronix Enforcer comms issue
Not yet. Good idea, i'll be disconnecting the mains and battery tommorow when  I do the bell.
  • Replies 71
  • Views 47.4k
  • 3 attempts at communicating every time the the system is open or closed...   Digi programmed ?   so-   4 wired zems on an enforcer + wired bell(s) ?   all
  • +150mA for the controls ?   + bell, modern low current one 60mA in day   call it 500ma for easy math ?   lets call the 2200mA panel battery 2.5A for easy math?
  • I did get a 55sec BB off at 11.59pm last night and a 3 minute off at 9.17am but the alarm didn't Comm fault which is okay with me.
You sure you dont have anything programmed into the arc settings?
Also if the zems, ewd and detection are all powered off the panel you are overloading the power supply. Are they the mains powered zems with their own battery or the small ones?
Edited by petrolhead
Ah you see dude turns up and remembers all these terms , arc settings as he says or a Digi mistake somewhere
Or reboot might work lol
Out of interest why would you fit an enforcer when a euro 46 is the more appropriate panel for the job?
Pretty sure it says 485 fail when it cant poll a zem, comm fail would be signalling
How many h/w pirs fitted?
As above sounds line to much being driven off the panel.
Has all detection been successfully walk tested? Voltages at detectors?
For Comms issue?
Come on man , enforcer is more DIY friendly no? When doing wireless though....
8 minutes ago, petrolhead said:
Neither is a diy panel. Doesnt stop arseholes selling them to diyers though.
Diyers fitting this gear hardcore
Whoever sold it to you must have a technical helpline. Just call them and have them talk you through it while your at the keypad.....
