When I use the code, the alarm seems to set properly. When i use the code followed by #  , the upper number 8 continues to flash.
  • Replies 30
  • Views 10.8k
  • https://www.gov.uk/government/publications/smoke-and-carbon-monoxide-alarms-explanatory-booklet-for-landlords/the-smoke-and-carbon-monoxide-alarm-england-regulations-2015-qa-booklet-for-the-private-re
Are there any smoke detectors on the system?
If that's what the flashing  8 means . How do I identify what zone 8 is ?
Norman asked if a smoke detector is linked. There is a smoke detector however I don't know if it is linked . How could I discover if it is.
Thanks for the interest by the way.
I thought a faulty zone would be a steady led, but I must admit I can't remember, hence asking if it's a fire zone that's tripped.
The only real way to tell is to either find the paperwork that identifies the zones or get a competent person in who can sort it and service it maybe @ the same time.
If your landlord had it fitted they may have the paperwork, and in most cases it's up to them to resolve in any case.
Picture of smoke detector?
I will get a photo of the detector tomorrow with a little luck.
Smoke detector is battery operated and not connected to the mains.
Personally I'd refer back to your landlord and let him sort it.
So then unlikely connected to alarm
