Citadel XR2
Hi, just been to a job today involving a Citadel XR2. Looks like an ADE Accenta/Optima. Managed eventually to default it to factory settings and program it (mostly)  . The programming seems to be a mixture of original Optima (EE times) and some G3.
Also is set to Engineer reset by default unless I’ve inadvertently done this or just defaulted codes only.
Does anybody have a link for the Engineer Manual to save the detective work.
Thanks
  • Replies 22
  • Views 8.6k
  • petrolhead
    petrolhead
    https://www.ebay.co.uk/itm/Haynes-Car-Manual-Mk2-Fiesta-Xr2-/152843816501
  • Look Mr Happy if you havent got a Citadel XR2 manual just say so. Read my posts properly and most people should realise I’m not Mr Numpty. I said I have all the ADE manuals and that the programming is
  • sixwheeledbeast
    sixwheeledbeast
    We have a good range of ADE (Concept/Optima/Accenta) manuals in our engineers downloads section, accessible to trade verified members. We do not distribute manuals here in the forums for security
There's lot of different ade products which look the same & it gets worse when rebranded... I'd prefer to bin it off
Thanks but panel works fine and the customer would rather reset themselves with the engineer code than buy a new one. I just need the manual  and it will be sorted out in seconds.
Sorry didn’t take a photo but I would say looking at the optima/accenta 8 manual it is the same. It’s not like the g3.
The entry and exit timers are programmed like the original optima ie 1 or 2 from the engineer mode followed by 01 for 10 seconds etc but the engineer code etc goes in like the g3.
I would guess the engineer reset option would be in the system flags like the accenta 8 but didn’t try this on site.
Would be nice to have the manual to eliminate the trial and error.
Thanks
IIRC xr1 is panel with on board keys x2 is panel & keypad
when the ADE product changed models Senate still called there's XR
You need product knowledge of ADE pcbs to you guess what your "xr"is really is
There not graded & the programming makes little sense to me, I take the view that paying me an hr to program it is better spent fitting better controls
8 hours ago, MrHappy said:
You have picture of the PCB ?
Need picture of PCB , otherwise keeping guessing , or if it's some mutant PCB even more guessing
We do not distribute manuals here in the forums for security reasons as per our guidelines.
If similar to Accenta G3 it will be in Flags so:-
Option 3 > Flag 3/4 (off) > Reset
This shouldn't be on as default so I can only assume the panel wasn't defaulted fully or you switched it on by accident.
