I could do with some help
What I have done is this.
Took the smoke dec off and then entered my pin number.. so that should stop the internal alarm from sounding?
Where could I buy one of these?
3 minutes ago, norman said:
No they won't tell you it, but they will come out and default it for you (for a cost obviously), much cheaper than a sleepless night...
Why would I have to pay again? I paid for the system in the first place!
Edited by PhilUK
  • Replies 24
  • Views 5.1k
  • Give them a call and explain that, let us know how you get on.
  • I would not need any codes to work on your existing system     What a set of bastards... imagine your next disappointment when you discoverer the smoke detectors not been manufactured
  • Just link it out, no come back from dead people...
17 years ago you bought a car, would you expect someone to come out for free to decode the radio....
the best place to buy an A2Z Smoke would be CSD Professional
Which should have been changed in 2010. Although unless you've remembered your installation dates wrong, a little unfair, IMHO, for a large company to be fitting 2 year sat on the shelf detectors.
Even I would rotate / manage stock enough to avoid a 2 year old detector with a ten year life being fitted. But anyway, this is now and 15 years later just a little unfair for you to expect a free visit.
Also I mis-read your first post where I thought you meant you didn't (or were not aware) of having a fire alarm
Edited by datadiffusion
Your paying for them to fix it, what you paid for the system doesnt cover free callouts forever.
No.. I don t want them to fix it. I want the code so that I can disable zone 6 and without that code I cant disable it.
Edited by PhilUK
But if they give you their unique engineers code then they compromise every system with the same code...
Give BMW a call and ask for the code for the 2017 map updates
Yes, I understand that however maybe if you buy a closed system they make that code your pin or something. its fine. taking the smoke thing off the wall has worked for now.
If I can find another replacement ill replace it with it. hopefully what its connected to, will not need to be changed.
Edited by PhilUK
Well if you wanted to fix it yourself you should have told them when they installed it, they would have fitted a DIY system
Well, I guess you only need it when something has gone wrong! so 17 years later I find this out.. its ok because I know now.
