HKC blocking dial capture units
ok ty very decent of you. out of interest why the rip out?
1 hour ago, james.wilson said:
if its not locked ill have it
you working on a weekend?
To fast , see your pm please
1 hour ago, Lwillis said:
I'm ripping out a 1070 at the weekend if anyone want it otherwise it's going in the bin.
Little while back you were desperate to put it in lol
as I'm quoting you here do i need an alarm?
Eh?
To fast asked for panel lol
Desperate to install was Willis
You smoking?
It's been in about a year I think.... maybe less
can't have 0 in the code -Wife won't use system due to that and doesn't want a fob
wont take 1k/1k EOLs without fitting extra resistors in the panel
Redecorating throughout so fitting a more cosmetically friendly rkp
I guess it actually stops the user entering a zero?
UK (i.e. ancient) version of bloody 9651 didn't let you have zero as first digit, since that notified the system an engineer code was about to be used.
But... still lets the mongs use a 'zero' at code change time (it says not to in manual) then that's it, once timed out or logged out it'll never work again without defaulting :(
no 0 is cancel on it so customers can't get out of sequence entering codes etc
Lol that's funny , I got used the zeros been fitting them for two years and almost close to ripping out my dimension lol
