Euro 46 app panel
  • Replies 21
  • Views 12.1k
  • Created
  • Last Reply
Top Posters In This Topic
3 hours ago, sixwheeledbeast said:
You can't, without bodging the shunt loops around with spare pairs.
Marvellous, lets hope the intermediate wire isn't crushed or shorted, which would read as a permanent secure zone at the panel.
Well done Pyronix for having this bodge documented.
4 hours ago, datadiffusion said:
Yep as above it always threw me why people though you could 'chain' EOL then found out that gal supports it!
TS Menvier & early Premier did multipal eol devices
4 hours ago, james.wilson said:
no afaik only the galaxy supports eol like that
also the area mismatch iirc means you have things in areas but no keypad assigned etc
+ aslso
radio devices added but not zones not programmed / zoned programmed radio device not learnt
1 hour ago, bazza1981 said:
just contacted pyronix they said eol on two devices will work
2 Contacts to 1 Zone 4k7_2k2.pdf
Lol I can imagine our service engineers getting confused by that. Keep it simple is the moto!
I'd say its much easier way to do 2 devices  in series but use different resistor values?
Edited by MrHappy
We normally fit Knight G2 contacts that allow for this.
YEND74 MULTI.pdf
It's an old job with shock contacts is the document from pyronix not a good idea to use?
YEND74 MULTI.pdf
I reckon theres a easier way to wire double doors on a euro than their diagram
you could use their diagram or use dp.
best to not but u do have existing cabling to work with
