3 hours ago, sixwheeledbeast said:
You can't, without bodging the shunt loops around with spare pairs.
Marvellous, lets hope the intermediate wire isn't crushed or shorted, which would read as a permanent secure zone at the panel.
Well done Pyronix for having this bodge documented.
4 hours ago, datadiffusion said:
Yep as above it always threw me why people though you could 'chain' EOL then found out that gal supports it!
TS Menvier & early Premier did multipal eol devices
4 hours ago, james.wilson said:
no afaik only the galaxy supports eol like that
also the area mismatch iirc means you have things in areas but no keypad assigned etc
+ aslso
radio devices added but not zones not programmed / zoned programmed radio device not learnt
1 hour ago, bazza1981 said:
just contacted pyronix they said eol on two devices will work
2 Contacts to 1 Zone 4k7_2k2.pdf
Lol I can imagine our service engineers getting confused by that. Keep it simple is the moto!
I'd say its much easier way to do 2 devices  in series but use different resistor values?
Edited by MrHappy
2 hours ago, Amps said:
We normally fit Knight G2 contacts that allow for this.
YEND74 MULTI.pdf
I reckon theres a easier way to wire double doors on a euro than their diagram
17 hours ago, bazza1981 said:
It's an old job with shock contacts is the document from pyronix not a good idea to use?
you could use their diagram or use dp.
best to not but u do have existing cabling to work with
Register a new account
Sign in
