neon555 Posted August 27, 2017 Share Posted August 27, 2017 Hello all, A few months back I installed a Texecom Premier Elite 48 control panel, with Ricochet PIR's, door contacts, a could of hard wired devices. Along-side this system, I wanted to be able to be alerted to any alarms so bought a GSM communicator plugin for it. The part number is CEG1000. The set-up took a few reads of the manual, but I got there and it was all working very well, it was tested, receiving messages, replying to them and alerting me if an alarm was activated. A few weeks after installation the system started beeping intermittently and gave me an error message: ATH Path Fault COM1 Fault No ATS Available. I put it into engineer mode, disconnected the communicator from COM1, opened it up, gave it a good old clean out and plugged it back in. The system happily accepted it and all was right in the security world. The device then started to throw this error again, and it grew more frequent, first a month, then a fortnight, a week, a day, an hour, and now it is a matter of seconds. I'm wondering if someone could point me towards exactly what I should be looking at, as the cause of the issue. I have verified the sim card works, the panel is communicating with the GSM device and vice versa. Having looked around the forum I have found many people with this error, but they all seem to be using the DigiCom devices which are connected to the phone lines. The GSM module was bought second hand, so I am aware that this may play a part, but before I get in contact with the person it was purchased from, I want to make sure I rule out all other problems. Anything I can try and test would be greatly appreciated. John Picture of device: http://imgur.com/a/F3BU0 Picture of model: http://imgur.com/a/10vou Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41515-texecom-gsm-problem/ Share on other sites More sharing options...
al-yeti Posted August 27, 2017 Share Posted August 27, 2017 What do you mean have it a good old clean? And what happens if you remove the gsm unit completely , is it that the GSM signal is dropping out and it is looking for an alternative path ? But you don't have one The gsm device what type of antenna is it , communication doesn't mean it isn't dropping out Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41515-texecom-gsm-problem/#findComment-467884 Share on other sites More sharing options...
neon555 Posted August 27, 2017 Author Share Posted August 27, 2017 I literally mean what I said. I dismantled the device, ensured there was not dust between the sim card and any of the contacts, or anywhere else within the device or the system itself. I'm not sure I understand what you mean about removing the GSM unit completely. Well the error stops of course, because there is no unit there. As for the signal dropping out, there is a chart in the manual: http://imgur.com/a/OWSIj Lights 1 & 2 either stay solid green or flash, indicating they are communication or ready to communicate. Light 3 confuses me a little because it flashes quite rapidly, but the chart doesn't list anything about fast flashing. Perhaps it is slow flashing and I am misinterpreting it. The antenna is the one which came with it: http://imgur.com/a/GivHQ - note; I am aware it is not screwed into the wall and this has been on my to do list, but as I previously said it was working perfectly for quite some times before the issues persisted. If you think this could make a difference, I'm happy to go and get that done now. My understanding with GSM is if it drops out, it will just reconnect at the first available opportunity. Could increasing the ATS fault setting help in this issue do you think? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41515-texecom-gsm-problem/#findComment-467886 Share on other sites More sharing options...
al-yeti Posted August 27, 2017 Share Posted August 27, 2017 Ok let's wait for swb and others now that you have given more info dude Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41515-texecom-gsm-problem/#findComment-467887 Share on other sites More sharing options...
sixwheeledbeast Posted August 27, 2017 Share Posted August 27, 2017 Increasing the ATS Fault delay would only mask an issue. The aerial could do with mounting correctly, making sure it's the right way round. The unit should be powered down from the COM port if you remove the SIM for whatever reason, which I believe you did? The third light flashing indicates you have marginal signal so I would assume it's just a case of poor signal. Try resiting the aerial or switching networks until your signal is good, solid light. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41515-texecom-gsm-problem/#findComment-467891 Share on other sites More sharing options...
al-yeti Posted August 27, 2017 Share Posted August 27, 2017 26 minutes ago, sixwheeledbeast said: Increasing the ATS Fault delay would only mask an issue. The aerial could do with mounting correctly, making sure it's the right way round. The unit should be powered down from the COM port if you remove the SIM for whatever reason, which I believe you did? The third light flashing indicates you have marginal signal so I would assume it's just a case of poor signal. Try resiting the aerial or switching networks until your signal is good, solid light. Swb hardcore as usual Can he get a different antenna? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41515-texecom-gsm-problem/#findComment-467894 Share on other sites More sharing options...
neon555 Posted August 28, 2017 Author Share Posted August 28, 2017 (edited) 20 hours ago, sixwheeledbeast said: Increasing the ATS Fault delay would only mask an issue. The aerial could do with mounting correctly, making sure it's the right way round. The unit should be powered down from the COM port if you remove the SIM for whatever reason, which I believe you did? The third light flashing indicates you have marginal signal so I would assume it's just a case of poor signal. Try resiting the aerial or switching networks until your signal is good, solid light. In regards to mounting the antenna correctly, this won't be a problem, however you mention "making sure it is the right way round". The manual I have doesn't mention mounting it any specific way. I have attached the manual I've been following. Where I live is notorious for bad signal, so I'm going to try a different sim card on a network I know has better coverage I will report back as soon as I have any updates. Also sixwheeled beast, al-yeti made a comment about another antenna. I am interested in getting the best signal possible, I presume any GSM antenna will work with this device? ##Manual Removed### Edited August 28, 2017 by sixwheeledbeast No manuals posted in public please. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41515-texecom-gsm-problem/#findComment-467918 Share on other sites More sharing options...
sixwheeledbeast Posted August 28, 2017 Share Posted August 28, 2017 T-Bar aerials normally have a indicator for ground, which should point down to the ground. You can try different aerials but you have to be careful you don't create more issues. For example, you could use a longer aerial (or extension) to get to an area of better coverage, however, the longer cable could decrease the benefits from that. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41515-texecom-gsm-problem/#findComment-467921 Share on other sites More sharing options...
james.wilson Posted August 28, 2017 Share Posted August 28, 2017 I hate tbar aerials, i like the stubby that Webway offer as a premium over the hateful (imo) tbar 4 hours ago, sixwheeledbeast said: T-Bar aerials normally have a indicator for ground, which should point down to the ground. You can try different aerials but you have to be careful you don't create more issues. For example, you could use a longer aerial (or extension) to get to an area of better coverage, however, the longer cable could decrease the benefits from that. but as above often a high gain will also receive more noise too and then loose the good signal in cable losses securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41515-texecom-gsm-problem/#findComment-467939 Share on other sites More sharing options...
al-yeti Posted August 28, 2017 Share Posted August 28, 2017 Cost of it is worth a try Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41515-texecom-gsm-problem/#findComment-467944 Share on other sites More sharing options...
