Wireshark
I was bored the other day & was messing at work, using Wireshark I can see everything on my network sending packets of data (whatever) as expected.
Our alarm signals via a TCD,oddly I can't see any data connected to its IP ?
I can see data when I ping.....
Being just a simple alarm monkey... can anyone explains whats happening ?
is the signalling using udp or tcp?
You wont see all traffic on the network unless you are using an ancient hub or a managed switch with port mirroring, some traffic will be invisible to the machine running wireshark, most of the traffic you see will be broadcast traffic.
I was expecting TCP, but saw nothing
 I don't really understand it, but having a play
Switch is old Procurve 2626,
I use Fing on my phone, its quite handy when your on a public network and you want to see what else is on it
I can't say I've ever wanted to know.
You can never be too careful, I like to be sure who is around me before I start looking at the stuff youve posted in the Mod lounge
are your eyes really that bad?
Theyre nearly as bad as yours
