MrHappy Posted July 18, 2017 Share Posted July 18, 2017 41 minutes ago, james.wilson said: id say its a pir with a range pot I'm changing my answer... Visonic DT still late 80's The pic need rotating to the right, the jumper between pyro & leds is marked "m/w" Dt bit is the flat pcb type Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41404-hard-wired-pir-fault/page/2/#findComment-466050 Share on other sites More sharing options...
Muttsnutts Posted July 18, 2017 Author Share Posted July 18, 2017 Thanks all to the replies after leaving the system disconnected and re connecting after 24 hrs it seemed to have cured itself, I may still wire in a new pir sensor as lots of comments saying it old and could be past it's used by date. Just randomly put the jumpers in any position. Any recommendations on a new sensor not looking to spend the Earth. https://www.toolstation.com/shop/p34020?table=no Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41404-hard-wired-pir-fault/page/2/#findComment-466051 Share on other sites More sharing options...
MrHappy Posted July 18, 2017 Share Posted July 18, 2017 1 minute ago, Muttsnutts said: Thanks all to the replies after leaving the system disconnected and re connecting after 24 hrs it seemed to have cured itself, I may still wire in a new pir sensor as lots of comments saying it old and could be past it's used by date. Just randomly put the jumpers in any position. Any recommendations on a new sensor not looking to spend the Earth. https://www.toolstation.com/shop/p34020?table=no post a pic of the full sensor... Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41404-hard-wired-pir-fault/page/2/#findComment-466052 Share on other sites More sharing options...
Muttsnutts Posted July 18, 2017 Author Share Posted July 18, 2017 1 hour ago, MrHappy said: post a pic of the full sensor... It's back in the work shop as soon as I'm back in there tomorrow I will do. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41404-hard-wired-pir-fault/page/2/#findComment-466054 Share on other sites More sharing options...
datadiffusion Posted July 18, 2017 Share Posted July 18, 2017 If this is an unheated workshop the 'off brand' PIR in the Toolstation link would be unsuitable. Im guessing not much of value in said workshop? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41404-hard-wired-pir-fault/page/2/#findComment-466056 Share on other sites More sharing options...
Muttsnutts Posted July 19, 2017 Author Share Posted July 19, 2017 (edited) 11 hours ago, datadiffusion said: If this is an unheated workshop the 'off brand' PIR in the Toolstation link would be unsuitable. Im guessing not much of value in said workshop? Well the workshop has been extended/built which cost quite a bit so I've used existing old alarm which was out of use got back up and running with new battery etc (optima xm6)....and moved into new side of workshop. It has quite a lot of kit in and has a lot of value I was just trying not to overspend for the sake of it, so next idea for a sensor lol .I'm going to get a full pic of old sensor now. Edited July 19, 2017 by Muttsnutts Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41404-hard-wired-pir-fault/page/2/#findComment-466068 Share on other sites More sharing options...
norman Posted July 19, 2017 Share Posted July 19, 2017 37 minutes ago, Muttsnutts said: It has quite a lot of kit in and has a lot of value 37 minutes ago, Muttsnutts said: I was just trying not to overspend for the sake of it, This is the train of thought with a lot of people sadly, when you turn up and your doors are swinging in the wind and your nice, expensive kit has gone the savings will pale into insignificance. Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41404-hard-wired-pir-fault/page/2/#findComment-466072 Share on other sites More sharing options...
Muttsnutts Posted July 19, 2017 Author Share Posted July 19, 2017 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41404-hard-wired-pir-fault/page/2/#findComment-466073 Share on other sites More sharing options...
aissecur Posted July 19, 2017 Share Posted July 19, 2017 im still sticking with electronics line micro X (maybe early version) 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41404-hard-wired-pir-fault/page/2/#findComment-466074 Share on other sites More sharing options...
norman Posted July 19, 2017 Share Posted July 19, 2017 Is that PCB in the case upside down? Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41404-hard-wired-pir-fault/page/2/#findComment-466075 Share on other sites More sharing options...
