Visonic Powermaster 10 help
I have a Powermaster 10 and have just bought an external siren (MCS-730) and the Powerlink3 module.
I can't enrol the siren. There is no enrol button on the pcb and I have tried pressing the test button but this just sets off the alarm.
The Powerlink module doesn't work either. Option 7 in the setup menu doesn't exist and the manual says that if this is the case, then make sure it's installed properly. It only has a flat ribbon cable and network lead, so not much to do wrong there. The packet was labelled Tyco and I wondered if it was specific to them?
Not much help on the internet for this system and I think I may have made a mistake getting it.
adt Visonic wont work with mainstream Visonic.
Won't all parts have 'tyco' on though as ADT or not they still own Visonic?
Edited by datadiffusion
6 minutes ago, Kevalino said:
Thank you! Wondered if this was the problem. Any idea on the siren?
Plenty on eBay i assume
Nah unlikely
3 minutes ago, al-yeti said:
Nah unlikely
Why not? Even the webby shouts it out, unlike many others who keep their ultimate ownership quiet, i.e. you won't find 'Mondelez' (Cadbury) on Green & Blacks bars.
Not solved my problems yet but at least there is somebody out there who knows about the Visonic system!
the adt/tyco system is different. They lock it to their version, as they should cos all are sold at a loss. Unfortunately this ends up on ebay (non paying customers or van stock or... etc)
If you have an adt panel you need at least adt peripherals. If you have a non adt panel the nicked stuff wont work with it
Thanks, James. Had no idea about this - will try to get a refund and buy a proper one!
Doesn't matter the MCS730 is for the Powermax anyway.
They have different sirens but look the same.
