Gardtec 595 Panel- Keypad Swap Out
See attached i have an old KEYPAD on a Gardtec 595 Panel the screen has went, i have tried to swap it out with this new 4 Wire Blue LCD Keypad however it does not work does anyone know a way of getting it to work with resistors or do i need to send this back to Risco Group and get a 6 Wire Version?
If i need to send back and get a 6 Wire Version does anyone know if it is available in Blue LCD?
Thanks Jack Buchan
JDB Solutions
Edited by james.wilson
no contact detail in post
  • Replies 28
  • Views 10.7k
  • james.wilson
    james.wilson
    back on topic i want a hidden one fitted, what are my options?
  • datadiffusion
    datadiffusion
    Come on Grandad, that's what the quote button's for!         (joke)
  • PeterJames
    PeterJames
    I am sure thats what I said? No need to apologise, I occasionally get things wrong too, us oldies have to stick together
According to the manual page you've photographed, it should be fine...
I'm guessing you've done a panel cold start?
jack i thought you were going into tow bars?
iirc the old 6 wire is dead, there may be some old sh## around
First down power the panel and switch back on to see if the blue LCD keypad goes through its startup.
If you are getting the same you get the 6 wire keypads but they are not blue LCD.
Hi James yes we do fit thousands of Towbars Did you remember me ?
12 hours ago, PeterJames said:
you can still get 6 wire not sure if they are blue or not
Ok thanks
Ok il try this although Risco told me it won't be compatible
Westfallia removable, or spunk out on an electric retractable.
is the removable one totally hidden when removed, ie also the socket?
Depends I think, on my old one the socket was out of sight. I hate seeing towbars or the gubbins of them.
