IP intercom across 4 PC's
Does anyone know of an IP intercom system that can have 4 external call buttons each going to a different PC to be answered per department.
HIK intercom should be able to do this having a play with one tomorrow
Comelt will work with ease but will require dongle for each PC it is running so cost may be a problem
43 minutes ago, PeterJames said:
comlit VIP
Can be done with hik but need ivms running. Can't you fit the touschscreens? Or if you want audio only and they have a sip server and voip phones or sip client software on the pcs something like a fanvil?
  • 1 year later...
  • 11 months later...
I'm about to install the HIK system (2nd generation) with 4 of their little monitors which do this out of the box, allegedly. They're not cheap but possibly more effective/efficient than keeping iVMS running all the time.
