Galaxy Flex With Activ8 Colour Camera & App
Evening Guys - long time listener first time caller here,
I work with 24v & never touch 12v so please take it is easy with me.
I am installing a Galaxy Flex 20 with Internet module in my house & am wondering if the Activ8 PIR With Colour Camera can transmit live video images to the Honeywell GX RC app via the internet card?
If not, what benefits does the Activ8 PIR with colour camera provide?
...I am not linking to an ARC.
Many Thanks.
no its a hard wired camera pir for connecting do a dvr etc
Oh and welcome by the way
Thanks James. What are the cable/voltage requirements for this device?
12v and alarm cable for the detector, coax if long for the camera. Its main use is for detector activated cctv or covert use
7.8 - 16Vdc drawing 135mA
Coax or UTP and baluns I would assume for video. Alarm cable for the alarm, and UTP for audio.
Looks like it's for covert CCTV use. Are you sure this is what you need?
Probably not.
Honeyhell describes this PIR as having the ability for the ARC to capture live feed/stills following an activation. As I wont be linked to an ARC I had hoped the live feed/stills may be able to be transmitted to the app.
Are you aware of any Galaxy Flex compatible device capable of relaying a live feed/stills to the app?
no, galaxyguy be your best bet.
The Flex supports a PIR sensor with integrated camera for intruder verification images. The images can only be pulled by the ARC and the app doesn't receive them.
You havnt got a hack then
