RISCO CPX BATTERY ISSUE
Purchased a new battery for the alarm system which is a risco cpx with a gardec 8 zone expander. The original battery in the alarm system is 5 years old so thouht better change it
The battery original fitted is a genessis np2.3 -12.  12v 2.3ah
I have fitted a new same make battery genessis np2.3-12 FR.    12v 2.3Ah
Upon fitting the new battery i am niw getting a fault on the key board that says. Fuse / battery fault  causing the internal alarm to go off.
Soon as  swap it back to my old battery the fault has gone.
Do you need to set or adjust any thing on this alarm system so it knows it has a new battery?
Or is it more than likely i have a faulty new battery or it is not compatible to my old one? As it says on the new battery NP 2.3 -12 FR. 12v 2.3ah.   And my original one does not say FR
Or is it just a straight forward plug and swap over no programming issue when changing the control panel battery?   so i have a faulty new battery?
Has any one come across this issue before please?
  • Replies 27
  • Views 7.2k
  • karl taylor
    karl taylor
    Hi sorry for delay   Old battery reads: 13.60volts   New battery which i am sending back reads: 11.28 volts!!   What should a new battery be as i have just ordered anothe
What voltage is showing on the new battery across the terminals?
Hang on, lets get the voltage first!
I think we can all guess what the problem is and the place of purchase will only confirm what we are all thinking.
Spoilsport.
it could be somewhere reputable
Oh. I think we were all thinking SW?
