Replacing old bell box with Pyronix DeltaBELL plus
Hello,
Just  after some advice about changing an old bell box for a Pyromix DeltaBELL plus. The panel is a Optima XM panel (quite old)
I am unsure of how many cores are going to the old bell as I am doing the job for a friend. I am an industrial electrician by trade so I have limited knowledge of alarms!
I have no manual for the new bell box but I am told there's 7 terminals. I'm due to go there this weekend so thought I'd do some homework before attempting it. Anyone on here have a diagram for this bell or any advice? I have the manual for the panel but not the new box.
Thank You!
Sorry we can't share manuals here.
I imagine it will be 5 wires, the other terminals may be for extra features.
Either way if 8 core, wire them all up and you can do whatever testing at the controls without being up and down the ladders.
Panel ov A to ov bell box
Panel 12v+D to 12v+bell box
Panel trigger B to bell ,bell box
Panel tamper return T to T bell box
Panel strobe -ov to St bell box
Put wire link from ov in bell box to the other T terminal
If you don't have enough cores for strobe and bell , use bell output only and loop over to the strobe input at bell so both activate on alarm
56 minutes ago, petrolhead said:
If you haven't bought it yet i would get the x not the plus.
Or offer it as an upgrade next time as module is straight swap and buy the lamp
