Veritas R8 help req
just replaced a blown caps on the main board of a veritas R8 alarm
got everything working again the only thing that I cannot do is it is programed to accept to arm it with just pressing full or part and I would like to have to put the user code in then full or part
I have looked  but cannot find a answer
I know I will get a answer here
thank you in anticipation
  • Replies 23
  • Views 5.1k
If you have blown caps it's likely to be old and not have the one button set feature.
Red LED on CPU?
yes it does it all works now but it arms with just pressing  full
before it blew I had to put the user code in then arm
disabling
I want to put the user code in then arm
Edited by Keighley
So it has a RED LED and you can just press full?
Pretty sure it doesn't have that option.
Later models are Menu 00 option 3
here is a photo of the key panel
in the manual it says that it can be programed so it is a one button arm via the engineer code but it doesn't tell you how or how to disable it
Edited by Keighley
I am pretty sure he means the single led in the middle of the large white system box, rather than the keypad
