September 13, 20169 yr Author comment_450112 ill have a look tomorrow thank you good night Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40429-keighley/page/2/#findComment-450112 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 14, 20169 yr Author comment_450137 You was 100 % right I was programing it the wrong way round all seems to work correct now just another 4 PIRs to go the only thing I have noticed is that the control box gets rather warm, I don't know if it was like this before I started on it, because it is in a cupboard and I have not felt at it before. I did leave the system in engineers mode over night and removed the panel front, then pulled the battery out as far as the wires would allow to see if it cooled over night but it was still quite warm the next day I.E. the battery and the panel, The Battery was replaced in 19/12/02 with a 7amp could you give me your thoughts on. this please. One other thing is there is a vocaliser still wired up to the alarm panel but not connected to any telephone line I will not be using this so could I just remove the wires that connect both units and then remove the vocaliser? again thank you for your assistance as I would have been scratching my head for days. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40429-keighley/page/2/#findComment-450137 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 14, 20169 yr comment_450139 The system will get warm near the transformer and regulator (left side) but it's possible the battery is faulty or the system is overloaded. You would have to test this out with a meter. Yep you can remove dialler starting at the panel end first. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40429-keighley/page/2/#findComment-450139 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 14, 20169 yr Author comment_450140 Hi again sixwheeledbeast I am nearly sure it is not over loaded because there is only 6 door contacts and one PIR in the system? I would say the battery gets too hot because it is at the opposite end to the transformer and it did not cool much over night outside of the control box. will I have to remove the battery to test it and will the alarm hold its settings with the battery removed?? thank you. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40429-keighley/page/2/#findComment-450140 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 14, 20169 yr comment_450142 36 minutes ago, Keighley said: The Battery was replaced in 19/12/02 with a 7amp could you give me your thoughts on. this please. I'd sold you a nice new in 2007, again in 2012 & guess what you'd be buying on or before dec 2017.... A nice new standby battery Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40429-keighley/page/2/#findComment-450142 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 14, 20169 yr comment_450143 Yes and Yes, I would just replace it. Lucky if you get 5 year out of them. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40429-keighley/page/2/#findComment-450143 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 14, 20169 yr Author comment_450144 Thank you I guess that means get a new battery?? can I remove the battery and leave the alarm turned on and in use until I get a brand new shinny battery ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40429-keighley/page/2/#findComment-450144 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 14, 20169 yr comment_450145 unplugging your knacked battery with have little effect on the system, a decent battery will make the system work for 8hrs or more without mains power Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40429-keighley/page/2/#findComment-450145 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 14, 20169 yr Author comment_450148 Thank you MrHappy and sixwheeledbeast I will be ordering a battery tomorrow before I do any more to the alarm again thank you all Only 101 days to Christmas!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40429-keighley/page/2/#findComment-450148 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 14, 20169 yr comment_450149 1 minute ago, Keighley said: Only 101 days to Christmas!!! Very nice but I think the fourm exclusively worships Zuul the Gatekeeper of Gozer ? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40429-keighley/page/2/#findComment-450149 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
