Setting up several users on the texecom via Wintex
Isn't the there a section for user options and select no to everything associated to that user accept arm and disarm and so on , don't know the panel but assume that's what it has
Thanks al-yeti.
I have unchecked everything except for user can: ARM, DISARM, OMIT and still some user menus are showing.  Also I want to stop a user from accidentally disabling things like the door chime, but it seems they can disable it by pressing the chime button.
The missus is very nervous of technical equipment, so I want to keep it as basic as possible.
I only need her to be able to set ARM/DISARM with the Tag.
No we don't need to part set or omit.
