June 21, 20169 yr comment_447523 Hi Folks Joe here, was wondering if anyone can help, i need to fit 2 ip cameras half dome style to a 3" diameter lighting pole back to back, (one facing one way & the 2nd one the opposite way) any tips for a cheap bracket or fixing to achieve this? Thanks & regards Joe Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40253-cctv-pole/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 21, 20169 yr comment_447524 Two pole mounts? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40253-cctv-pole/#findComment-447524 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 22, 20169 yr comment_447525 Maybe Mr H can Do a drawing of how you can lash something together , that works of course Must have a picture in his archives somewhere Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40253-cctv-pole/#findComment-447525 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 22, 20169 yr comment_447529 11 hours ago, al-yeti said: Maybe Mr H can Do a drawing of how you can lash something together , that works of course cheeky Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40253-cctv-pole/#findComment-447529 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 22, 20169 yr comment_447532 https://www.google.co.uk/search?q=pole+mount+plate+cctv&client=opera&hs=ToP&tbm=isch&imgil=zPrgAacsapvgTM%3A%3BkK18lK-YJxVltM%3Bhttp%253A%252F%252Fwww.cctvcamerapros.com%252FCCTV-Camera-Mounts-s%252F84.htm&source=iu&pf=m&fir=zPrgAacsapvgTM%3A%2CkK18lK-YJxVltM%2C_&usg=__OgqABCY9GGo9ZZTxBcUnFOQxWCI%3D&biw=1280&bih=728&ved=0ahUKEwjD9ZeZ3rvNAhXmAMAKHd5CCNIQyjcIOg&ei=DpJqV8O2H-aBgAbehaGQDQ#imgrc=zPrgAacsapvgTM%3A "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40253-cctv-pole/#findComment-447532 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
