Whats wrong with Yale?
On a two way system the detectors and control panel communicate with each other, the detector knows when the system is armed therefore they dont transmit detected movement when the system is unset. Two way control panels can also randomly pole the detection and if it does not receive a reply it knows it is missing. Some one way systems do have poling but this is initiated by the detector and the control panel is expecting a pole from each of the detectors within a set time period normally 24 or 12 hours. Sometimes with one way systems two detectors pole at the same time which makes the panel think that it is being compromised, or it just does not recognise the poling and goes into pole failure. I dont believe the Yale system poles at all, meaning that the panel would not know at all if the detector was missing.
  • Replies 23
  • Views 4.9k
  • Created
  • Last Reply
Many thanks for this informative reply, I really appreciate it.
I now feel like I know the flaws of these types of systems, and think when I move house I will switch to a decent Wired one.
Thanks again to all the really helpful replies.
I've been unable to give anybody 'kudos' which I thought was because I was using the Mobile Site, but I'm on a PC and still can;t, so I'm guessing it is because I'm new?
Either way many thanks for the replies everyone :)
  • 2 months later...
We've just published a blog about why these alarms are not great. Stick with graded wireless or wired if possible. If you look on my personal site, you can see what I think of the various systems.
https://www.pentestpartners.com/blog/alarm-systems-alarmingly-insecure-oh-the-irony/
The short of it - easy to jam, easy to replay disarm signals, you can sniff the PIN over-the-air if you use a remote keypad, you can brute-force the PIN as well. I reported these issues to Yale 4 years ago.
I have a blog, some of which is about alarm security and reverse engineering:
http://cybergibbons.com/
1 hour ago, cybergibbons said:
30 years ago alarms were all hard wired, with discrete components, and operated by key switches. 20 years ago, they have evolved to use microcontrollers, LCDs and keypads, but were still hard wired. 10 years ago, wireless alarms started to become common, along with bags of added functionality.
a radio alarm from 25 ish yrs ago-]
That was the earliest one I could see - 1993-ish. Were there any others around that time?
didnt yale rebadge the scantronic 500r?
They seem to have had a bit of an odd history with alarms, looks like they were a bit more like ADT a long while back, then went to just consumer, and are now back trying some pro installs.
sold via B&Q & incompatible with the 500r
think the 4700 came out 1st ?
