Amr Mohamed Gad Posted February 25, 2016 Share Posted February 25, 2016 i have problem also cannot connect to the network. please complete the device settings at your next access i need help plz i do every thing in manual but i can;t see my cameras Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39796-samsung-ipolis-epic/ Share on other sites More sharing options...
PeterJames Posted February 25, 2016 Share Posted February 25, 2016 Hi and welcome Can you connect locally using the local ip address? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39796-samsung-ipolis-epic/#findComment-441540 Share on other sites More sharing options...
al-yeti Posted February 25, 2016 Share Posted February 25, 2016 Samsung model? Most are easy to setup Most common mistake is the port , when you put the port in the app don't put the first one , its the faded one on the right something like 4524 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39796-samsung-ipolis-epic/#findComment-441542 Share on other sites More sharing options...
datadiffusion Posted February 26, 2016 Share Posted February 26, 2016 OP - have deleted your post as it simply asked for help again and included an email address. People are trying to help you - can you answer the questions above? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39796-samsung-ipolis-epic/#findComment-441591 Share on other sites More sharing options...
Amr Mohamed Gad Posted February 26, 2016 Author Share Posted February 26, 2016 i Can not connect locally using the local ip address? modle sdr-3102 n whene i login to my account in samsing site and point to the vedio icon give me the router page and in mobile five me cannot connect to the network. please complete the device setting at your next accsess Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39796-samsung-ipolis-epic/#findComment-441595 Share on other sites More sharing options...
ElecTech Posted February 26, 2016 Share Posted February 26, 2016 Seems ports aren't configured right, you seem to be hitting the router page instead of going through to the camera. I've had something similar where the router defaults on port 80, so had to change the dvr to 85 else there's a conflict! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39796-samsung-ipolis-epic/#findComment-441600 Share on other sites More sharing options...
Amr Mohamed Gad Posted February 26, 2016 Author Share Posted February 26, 2016 (edited) this is my picture of sitting plz help me www.smmms.net/p/1.jpg www.smmms.net/p/2.jpg www.smmms.net/p/3.jpg www.smmms.net/p/4.jpg www.smmms.net/p/5.jpg www.smmms.net/p/6.jpg www.smmms.net/p/7.jpg Edited February 26, 2016 by Amr Mohamed Gad Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39796-samsung-ipolis-epic/#findComment-441601 Share on other sites More sharing options...
ElecTech Posted February 26, 2016 Share Posted February 26, 2016 Change your HTTP port to 85 and make sure you open port 85 on your router. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39796-samsung-ipolis-epic/#findComment-441602 Share on other sites More sharing options...
Amr Mohamed Gad Posted February 26, 2016 Author Share Posted February 26, 2016 can you see the pic sir and tell me how ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39796-samsung-ipolis-epic/#findComment-441604 Share on other sites More sharing options...
al-yeti Posted February 26, 2016 Share Posted February 26, 2016 (edited) So 4524 is your port for the ipolis app You need to change the IP type to static Then change IP address to 192.168.1.200 so it's out of the way Then next issue will be port forwarding on your router itself Gateway will be probably as already set 192.168.1.1 Sorry looking at your pictures , although dmz shouldnt be permanently used its a good way to do it temporarily, but because your DVR is set to dhcp and router is pointing to static address it will end up changing And then better to use the smartviewer software or the ipolis app for smart phone as web viewer doesn't always work Edited February 26, 2016 by al-yeti Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39796-samsung-ipolis-epic/#findComment-441605 Share on other sites More sharing options...
