mountianrider Posted January 11, 2016 Share Posted January 11, 2016 Fitting HD CVI cameras with baluns, should I go for screened or norm cat5? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39561-cat-5-balun/ Share on other sites More sharing options...
Simlec Posted January 11, 2016 Share Posted January 11, 2016 Do they make baluns with screen connection ? pointless if they dont Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39561-cat-5-balun/#findComment-438192 Share on other sites More sharing options...
mountianrider Posted January 11, 2016 Author Share Posted January 11, 2016 Why do you have to use screened then? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39561-cat-5-balun/#findComment-438193 Share on other sites More sharing options...
Simlec Posted January 11, 2016 Share Posted January 11, 2016 Do you mean shielded cat5e the one with just the aluminum foil ? When you said screened I had the one with braiding and drain wire in mind. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39561-cat-5-balun/#findComment-438195 Share on other sites More sharing options...
Simlec Posted January 11, 2016 Share Posted January 11, 2016 There still is no connection for a shielded cat5e plug in the balun. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39561-cat-5-balun/#findComment-438196 Share on other sites More sharing options...
Lwillis Posted January 11, 2016 Share Posted January 11, 2016 Don't use cat5 if you can. Or watch for volt drop Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39561-cat-5-balun/#findComment-438197 Share on other sites More sharing options...
james.wilson Posted January 11, 2016 Share Posted January 11, 2016 Baluns are designed for utp so not screened securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39561-cat-5-balun/#findComment-438198 Share on other sites More sharing options...
mountianrider Posted January 11, 2016 Author Share Posted January 11, 2016 Thanks All. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39561-cat-5-balun/#findComment-438230 Share on other sites More sharing options...
JasonOfOz Posted January 11, 2016 Share Posted January 11, 2016 We made the mistake of using CAT-5 - CCA w/ baluns Never again! Our runs were less than 90m but still, this affected image quality - we had to boost it with additional PSUs to give it a good signal. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39561-cat-5-balun/#findComment-438232 Share on other sites More sharing options...
petrolhead Posted January 11, 2016 Share Posted January 11, 2016 Screened or shielded cable reduces the distance you can send video using baluns Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39561-cat-5-balun/#findComment-438241 Share on other sites More sharing options...
