SentryAlertSystems Posted June 7, 2015 Share Posted June 7, 2015 No unlikely If you can't ping the stuff either you setting something wrong I can assure you I have set the TCP rule exactly as it should be lol. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted June 7, 2015 Share Posted June 7, 2015 Having a similar issue with this exact router on sky broadband, Why even bother, A good enough for a home netgear or tp-link is less than an hour labour? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
SentryAlertSystems Posted June 7, 2015 Share Posted June 7, 2015 Why even bother, A good enough for a home netgear or tp-link is less than an hour labour? Thinking this may be the route I take, although, I just don't understand why it should be necessary. This is a freebie install I'm doing for a friend so trying to keep costs down. Now I remember why I don't install domestics anymore... Quote Link to comment Share on other sites More sharing options...
Lwillis Posted June 7, 2015 Share Posted June 7, 2015 Have you tried putting the DVR in this DMZ? Or using a lower port? I've done many sky routers and never had an issue getting into then or setting up ports or using dmz(I know DMZ isn't the most secure way or doing it) What sky router is it? Quote Link to comment Share on other sites More sharing options...
MrHappy Posted June 7, 2015 Share Posted June 7, 2015 Thinking this may be the route I take, although, I just don't understand why it should be necessary. I'm a simple alarm monkey.... I've tried to get Homehubs & Thompson Tecicolours to work, however it cheaper for the sub for pay for a router rather than pay me to prat about... Quote Mr Veritas God Link to comment Share on other sites More sharing options...
al-yeti Posted June 7, 2015 Share Posted June 7, 2015 Sky routers are one of easiest Work on internal ip first and try connecting there I assume it works indoors? Quote Link to comment Share on other sites More sharing options...
SentryAlertSystems Posted June 7, 2015 Share Posted June 7, 2015 (edited) Have you tried putting the DVR in this DMZ? Or using a lower port? I've done many sky routers and never had an issue getting into then or setting up ports or using dmz(I know DMZ isn't the most secure way or doing it) What sky router is it? Have tried enabling DMZ but no success. Is the 582n Technicolor. This is the first time I've ever had an issue setting up port forwarding too. One thing I have not tried is using a lower port number, port :37777 as default for NVR. Sky routers are one of easiest Work on internal ip first and try connecting there I assume it works indoors? yeah I can log into the front end no problem internally on the LAN. Edited June 7, 2015 by SentryAlertSystems Quote Link to comment Share on other sites More sharing options...
Lwillis Posted June 7, 2015 Share Posted June 7, 2015 Technicolours arnt too bad. Try a lower port number first. If you want I can teamviwer in and take a look? Quote Link to comment Share on other sites More sharing options...
SentryAlertSystems Posted June 7, 2015 Share Posted June 7, 2015 thank you Lwillis, i may just have to try a 4 digit port number instead of the default 5 digit? wont be back to site till next weekend but if im still having issues i may just take you up on that offer. i could open up the remote programming on the router and you can dial direct into that i think? port :51003?? i can still see any changes made live on my screen too i think. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted June 7, 2015 Share Posted June 7, 2015 Technicolours arnt too bad. IIRC remote management times out ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
